KM 5050 duplex printing error(cassette 1)
  • Crni
    • Mar 2014
    • 54
    Hi guys.
    My machine suddenly started giving me error when duplex printing from cassette 1. It was working fine before.
    1 case: It starts fine giving me 2 duplex prints then prints only on one side and ejects the paper, error pops out (paper jam) with next paper in line waits in the middle of paper feeder.
    2 case: Again starts good then ejects only one side print and the next paper starts coming out, error pops out (paper jam) with that next paper being half way out.
    Any ideas what is the cause of this ?
    Printing one sided on cassette 1 is ok and cassette 2 is printing duplex just fine.
  • Tonerkiller
    • Oct 2012
    • 665
    Re: KM 5050 duplex printing error(cassette 1)
    I would replace the turnover section
      • 22984
      Jam code? Media type? Media size? =^..^=
      • Kyo fan
        • Dec 2013
        • 368
        First print the event log and analyze latest jams you've had (use the service manual). In your case i would check middle feed assy (gear holder plastic can break) and as Tonerkiller mentioned, turnover section on the left side big door which can deform due to fuser hear and toner likes to stick to it.
        • Crni
          • Mar 2014
          • 54
          Code is JAM61, plain A4 paper. Yesterday I did find a small plastic holder ring in my Cassette 1 tray. Don't know where it came from :/
          • Kyo fan
            • Dec 2013
            • 368
            In that case the duplex paper conveying switch DUPPCSW or feed switch 1 FSW1 (also check it's actuator) could be faulty. Run U031 and turn those switches on and off manually.
            • Crni
              • Mar 2014
              • 54
              Hey guys problem fixed for now !
              I disassembled mid feeder section and cleaned all the rollers, I spread the springs behind the rollers.
              Found that the plastic holder ring was from small clutch motor on mid left section, assembled all and now duplex is working .
              I don't know if the holder ring was to blame or dirty(and old) rollers, springs.
              I suspect the rollers didn't have grip to pull back the paper but then Cassette 2 wouldn't work also hm hm.
              What type of grease or oil do you use for those small rotating parts like plastic rollers? I noticed that there was some green grease applied.
              Anyone uses silicon spray?
                • 22984
                Originally posted by Crni
                ... What type of grease or oil do you use for those small rotating parts like plastic rollers? I noticed that there was some green grease applied.
                Not silicone, not spray, not silicone spray. 3 in 1 Oil or TriFlow is preferred, and just a drop or two, only if it makes noise. Dry is better if it's quiet.
                • Zackuth
                  • Aug 2009
                  • 448
                  Take a look at the feed tires, maybe replace them first. I know this sounds strange, but I had a machine with the exact same problem as the one you describe and feed tires was the fix.
                  If at first you don't succeed, redefine success
                  • Crni
                    • Mar 2014
                    • 54
                    Well I can't find that oil in Croatia And if I get it over ebay I don't know if it will be original.
                    Any other lubricants that are good enough?
                    PS
                    So I need a dry oil lubricant?
                      • 22984
                      Any kind of light sewing machine oil is fine. =^..^=
                      • Donnie
                        • Aug 2011
                        • 79
                        Replace entire vertical feed assy.
