F050 then F040
  • ntbann
    • Jan 2012
    • 631
    F050 then F040
    We have a taskalpha 4550ci new out of box that we flashed with new firmware. during flash the mailbox update failed. Powered the machine down and up again and got the f050 error. Re-seated all connectors on engine pwb and got the machine to finally make it through full firmware up date but now we have the F040 error. Any suggestions would be helpful.
    Thanks in advance,
    NTBANN
    • 23010
    Re: F050 then F040
    Engine checksum error, and Engine communication errors, respectively. My guess is that the engine board will need to be replaced, and new firmware flashed. =^..^=
    • ntbann
      • Jan 2012
      • 631
      Re: F050 then F040
      Thanks BlackCat! That's what I was thinking. I just wanted a second opinion before I ordered it.
      • Kyo fan
        • Dec 2013
        • 368
        Re: F050 then F040
        It sux when you get that on a brand new machine. Did you have any issues that required firmware upgrade in the first place? Overall I'm satisfied with TA 3050ci and up series, but you would be much better off with TA 4551ci, couse that "1" in the end usually translates as: "hopefully we fixed all the fuckups and implemented all the changes from service bulletins so you can sleep well now".
        For those errors i would 1st check the connections between main pwb -> engine pwb and reseat those connectors. If it doesn't help, it's what Blackcat said. Good luck.
        • ntbann
          • Jan 2012
          • 631
          Re: F050 then F040
          Kyo
          I reseated all connectors. This mach was in warehouse and owner wanted it set up. I ordered the board today. Will keep posted. Thanks for response.
