Kyocera FS-1035 error C7990
  • fernando
    [Error Code] Kyocera FS-1035 error C7990
    Hi, I have an error code C7990 on a Kyocera FS-1035 MFP. Can someone help me on translation and fix of this error?
    Thank you.
  • GESPAGE
    • May 2011
    • 40
    Re: Kyocera FS-1035 error C7990
    Waste toner full. The waste toner sensor has detected that the waste toner reservoir (drum unit) is full.
    Waste toner reservoir (drum unit) is full = Turn the power switch off/on to restart the machine. If the error is not resolved, replace the drum unit
    Defective waste toner sensor = Replace the waste toner sensor.
    • fernando
      Hi, Thank you for your reply.
      I already changed the drum and image unit from another one we have here, and the error persist...
      The only thing I don't know where it stays, it's the sensor... can you give me some directions to find it for change it?
      • DWise
        • 895
        Fernando, you can probably contact Paul with JustManuals.com and get a Parts Manual and Service Manual for this model. You'll more than likely need them if you are going to service the printer.
        Do for one what you wished you could do for everyone. - Andy Stanley
        • taskalfaman
          • Nov 2009
          • 137
          it is located nearby the LSU-unit.
          the best way is to detach the complete scanner unit .
          have fun
          • fernando
            have fun
            Thank you taskalfaman, I will try to have some Fun...
            • Joe Foe from Buffalo
              • 399
              Have a fs 1028 same code its not the drum unit since it works in another machine. Please be a little more detailed about the sensor... location part #.....Is it next to the laser unit? I had the machine down to take laser unit out and didnt see it.
              • Kyo fan
                • Dec 2013
                • 368
                Doesn't matter if it worked in another machine. Take the drum unit out, open one of the sides and empty the waste toner. Restart the device after.
                • Ctl-Alt-Del
                  • Jul 2006
                  • 430
                  The waste toner tank is full, replace the drum unit (it's built into the drum unit).
                  • Alexkyocera
                    • Jul 2015
                    • 82
                    The Drum unit has two opening on either sides, pull them with a small flat screwdriver and vacuum, restart the machine, enter maintenance mode and reset the counter and you shoud be good, if your drum surface isnt damage that is
                    • subaro
                      • Oct 2010
                      • 1274
                      If you take a look at the service manual, it would show you exactly whrere it is located. just below the laser unit.
                      9. Toner sensor ................................................ Detects the quantity of toner in a toner container.
                        • 399
                        Remember this drum unit worked in two other machines. I emptied the toner unit an still went code on original machine. Ended up putting a used drum unit in to fix it an saving one that had the issue for a machine that has a service contract an is in need of one.
                        • tech28
                          • Jun 2013
                          • 434
                          Its in YouTube on how to remove and empty out. Good Luck.
                          • JAMCEOLA
                            • Sep 2015
                            • 2
                            Please take out the Drum Unit and empty the Waste Toner.
                            Sent from my TECNO-L5 using Tapatalk
