taskalpha 2550ci scan quality
  • michaelngun2121
    • Aug 2013
    • 6
    [Misc] taskalpha 2550ci scan quality
    My co-worker is handing off a call to me tomorrow that scans to email off glass fine, copies off glass fine, copies through doc feeder fine but when he scans through doc feed to email it comes out with dark grainy backround. He tried the doc feed luminosity adjust code 074, no difference. this is a new machine, updated firmware. any thoughts?
    Thanks in advance, never saw this problem before.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1897
    Re: taskalpha 2550ci scan quality
    Make sure the collared screw is in the correct spot. I've seen them installed backwards & it caused an image problem & I believe that was the symptom.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • AlbertK
      • Jul 2014
      • 90
      I had the exact same problem on one of the older KM2050's, I had to replace the ccd.
      The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
      • Kyo fan
        • Dec 2013
        • 368
        Post a sample if you can. Does i it happen on b/w or color scanning? yes, it matters, cause if it's color scans only, it can be fixed from the diagnostics.
        • michaelngun2121
          • Aug 2013
          • 6
          Yes the CQ is on color scan only but the yellow lines appear very faintly in B&W(as black lines). Copies are the same in color through doc feeder only. I am trying to attach a file here so you can see the mess.
          • Kyo fan
            • Dec 2013
            • 368
            First you need to give the slit glass a good cleaning both sides, use some alcohol liquid. Also flip the big glass and check the white strip on the left edge, it has to be clean. And last, check the white reference on the doc feeder (it's the metal that lays down on the slit glass).
            • michaelngun2121
              • Aug 2013
              • 6
              Problem solved, Usually the strangest problems are the stupidest problems. K.I.S.S. The scan lock was not fully disengaged by the set up person. This model has the scan lock on the rear of machine that releases a hook on the back of scan mirror. The hook was hitting the lock rail preventing scanner from hitting its alignment to slit glass!! I was on the right track though, I was trying code 68 for scanner alignment using DP.
              THANKS EVERYONE!! you guys are awesome
