TITLE TYPO: Should be "4551ci"
I'm trying to set up this machine the following way:
There are 4 cassettes: 2 plain letter, 1 letterhead letter and 1 plain legal. First, the customer wants it so that when paper to be copied is loaded into the ADF in portrait the copy is made on PLAIN letter and when it's loaded in landscape they want it to be copied onto the letterhead letter. All copies are default B&W, by the way.
Also, when printing they want default color to pull from one of the plain letter cassettes and when that primary cassette goes empty they want it to roll over to the secondary plain letter. BUT, if that cassette runs out they want it to stop printing instead of printing onto the letterhead (that's the closest I could get to the optimal solution--i.e. everything else works the way they want except prints will overflow to letterhead when all plain paper runs out). It just seems like I get one part working right and then I change a setting and it "breaks" the other part. I'm starting to wonder if this precise setup is even possible without some sort of workaround (like leaving a tray empty or something similar).
Is this possible with this machine? If so, what combination of settings could I use to make this work? If anyone needs any more info on the settings I'm using or anything else in order to help me out just let me know and I'll gladly provide.
Thanks in advance!
Thanks in advance!
