KM 2550 Blank area in center of Copies only
  • nzcowboys
    • Jun 2008
    • 12
    Hey Guy's,
    Have had three machines produce a 2 inch wide blank area in the center of the page when copying only (internal prints and external print jobs are fine)
    This can be intermittant or a hard fault.
    We know it cannot be anything to do with the engine and must be optical.
    I have read quite a few forums regarding this fault and have noticed the blue film on the center of the mirrors which I am not fully convinced is the whole story.
    Has anybody got to the bottom of this as I have had another machine produce this fault today.
    Any input would be much appreciated.
  • Jimbo1
    • Mar 2008
    • 845
    Just the basic facts...can you show me where it hurts?
    Does it happen from the glass, from the feeder or both?
    Need to eleminate something somewhere.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • nzcowboys
      • Jun 2008
      • 12
      Happens from both Document feeder and Glass.
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        white band
        Incontinentia Buttocks
          • 30248
          blank area
          clean mirrors with glass cleaner
          get a film on mirrors you can't see
          • knightfall
            • Jul 2006
            • 633
            I'm thinking that even with a blue haze on the optic there should still be enough light reflected back to the ccd to produce some image even light image but if there is no image a void of image I would think it would have to be the ccd that is causing the problem since you said printing an internal report prints out ok but not from the scanner (copyboard or doc feeder) that is where I would start.
            Get your facts first, and then you can distort them as much as you please.
            • brasilmichaele
              • Jul 2008
              • 31
              i would clean all the mirrors with alcohol. i have had the same issue on the km2050 also
              • brasilmichaele
                • Jul 2008
                • 31
                Originally posted by nzcowboys
                Hey Guy's,
                i have had this problem on the km2050. i cleaned the mirrors with alcohol and took care of the issue
                • tech07
                  • Aug 2008
                  • 409
                  Re: KM 2550 Blank area in center of Copies only
                  I can almost guarentee you, it's optics/mirrors..you have to clean them very thoroughly
                  • Jude
                    • Oct 2009
                    • 256
                    Might want to check your dv unit but most likely optics. Use a flashlight against the mirrors and clean. Use alcohol.
                      • 23008
                      Originally posted by banginbishop
                      I've had the same problem. You do a smc report and this eliminates the engine side and as you say their is a blue haze on the optics. All I’ve done is cleaned it with a glass cleaner and so far so good but I’m possibly thinking it might be ozone but without looking at the machine or the parts manual I don’t know if it has a fan or filter by the upper left side that might need replacing.
                      I'll concur will all these gentlemen and/or ladies. The ozone can get quite dense on the slit glass, mirror3, and mirror2. It's very common on that whole series of machines.
                      I've had success with isolating the area between the fuser and scanner, by taping over holes in the scanner frame, and insulating the area between the left side cover and the scanner frame. The machine I'm thinking of now goes for more than a year between optics cleanings.
                      • MR Bill
                        • 532
                        Yes with blackcat. Also lower the fuser temp about 10 deagrees.
                        This guy posted this over 4 years ago. I bet he fixed it by now??
                        But good info anyway.
                        • madas
                          • Aug 2008
                          • 313
                          Hi.
                          Make sure you clean "All" the mirrors. we had a tech who missed out the top left mirror and it still looked the same.
                          madas
                          PS just noticed the date lol.
                          • daveh12
                            • Jul 2012
                            • 157
                            definitely the optics. clean thoroughly the optics and slit glass. problem should go away.
                            • nmfaxman
                              • 1702
                              Check the white plate on the glass.
                              If it reads dark where it should read white, all dark is white.
