The original issue was printing on glossy paper that is medium thick and they would have
horizontal magenta streaks but not heavy, more like it was part of the background.
I changed paper weight, type and set to glossy mode in the menus to match and it helped alot but it's just intermittent. Very strange.
Cleaned the charge rollers too.
Now, this issue of the horizontal green band, as you can see in the pics. Maybe a failing board?
Firmware is up to date.
They did state that they can let it run about 50 prints then "let it cool down a bit" to remedy
the issue for a while. Again, strange.
We've warrantied the Magenta DV unit and swapped the K and M drums to see if that was even
it, and same dang intermittent issue.
They haven't said anything about the magenta lately, so, we'll just have to see what time holds.
