Toner container not installed error (FS-6030 I know classed as a printer)
+ More Options
Posts
  • madas
    • Aug 2008
    • 313
    Hi Guys
    I know this is not classed as a copier but have any of you had the issue where the m/c gives this message "Toner container not installed"
    I was told the toner was changed a couple of weeks ago and the message just appeared! asked about power outage told none.
    reset connectors on engine board, m/c is in an office environment so quite clean.
    I have tried a new toner but still the same message, it was late friday and I didn't have a manual to follow so I couldn't find the switch that activates when a toner is installed.
    Any thoughts?
    Cheers
  • AlbertK
    • Jul 2014
    • 90
    Re: Toner container not installed error (FS-6030 I know classed as a printer)
    Change the engine board, it is a known problem on these machines.
    The product may be brilliant and the salesperson proficient, but if the technician isnโ€™t efficient, then the story will end there.
    • kkendric
      • 301
      AlbertK is correct, a surface mounted resistor overheats and opens up causing this error.
      • madas
        • Aug 2008
        • 313
        Thanks for the input, you were correct! It was the engine board.
        Thanks for replying and hope I can return the help one day.
        madas
