FS-6030mfp Toner container not installed error
  • madas
    • Aug 2008
    • 313
    Hi Guys
    Have any of you had the issue where the m/c gives this message "Toner container not installed
    I was told the toner was changed a couple of weeks ago and the message just appeared! asked about power outage told none.
    reset connectors on engine board, m/c is in an office environment so quite clean.
    I have tried a new toner but still the same message, it was late friday and I didn't have a manual to follow so I couldn't find the switch that activates when a toner is installed.
    Any thoughts?
    Cheers
  • laitang
    • Nov 2012
    • 627
    Re: FS-6030mfp Toner container not installed error
    Check toner container switch [28]
    • AlbertK
      • Jul 2014
      • 90
      Change the engine board, it is a known problem on these machines.
      The product may be brilliant and the salesperson proficient, but if the technician isnโ€™t efficient, then the story will end there.
      • madas
        • Aug 2008
        • 313
        Thanks For the replies, AlberK you were spot on, thanks laitang for the diagram.
        engine board fixed the fault
        madas
