Kyocera TaskAlfa 4501i fax reporting
  • barber782
    • Aug 2011
    • 285
    Hi everyone,
    Could any help with switching on fax reporting on a Kyocera TaskAlfa 4501i ?
    Ideally need it to print out a TX and RX confirmation report.
    Iv already tried myself and found what I thought was the correct settings, but it still isn't working.
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera TaskAlfa 4501i fax reporting
    1. System menu > Report > Result report setting > Send result report, and change the fax value for sending.
    2. System menu > Report > Result report setting > Then press [Change] of FAX RX Result Report to either On, Off or Error only.
    It's all there in the fax operation guide, available for free from the manufacturer's website.
    • barber782
      • Aug 2011
      • 285
      Awesome many thanks for that, will give that a try.
