Kyocera CS255c Exit Jams
  • tecchie
    • 119
    [Jamming] Kyocera CS255c Exit Jams
    I have a customer with a Kyocera CS-255C Copier which they've had for about 1 1/2 years. We are getting consistent paper jams at the exit of machine more so as the machine gets hotter.
    I've heard Kyocera came out with a new exit section and revised fuser for this problem. Something about exit roller shafts warping when they get hot. I don't know how new this modification is but when I log onto Kyocera technical site I do not see one listed. Anyone know of this and if so do you have a bulletin release number I can look up. Thanks as always...
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera CS255c Exit Jams
    You are right, there are no bulletins mentioning fuser or exit unit changes. What jam exactly are you having? You can try doing a print with big door opened and the switch pressed to see if it will pass. If it does, it's likely that the exit unit is failing.
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      The roller warping issue shouldn't cause your jamming....what it caused was this awful squealing noise that would drive customers insane....and the fix was just a plastic L shape bushing to keep the shaft from rubbing on the frame...there was also a mod with the springs in the fuser pressure gear....they would break and cause a clicking noise and cause your pressure release to be out of alignment...but if you have a newer fuser these problems shouldn't be there...and wouldn't cause jamming...just annoying noise...
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
