Wanna see some cool copies?
    • 23009
    #16
    Re: Wanna see some cool copies?
    Originally posted by fishleg
    We have the exact same problem on a 8353ci. Engine board was swapped I think then it caused this.
    The dp colours are fine duplex but anything that uses the platen glass has the weird purple tint to everything.
    The board you are talking about is the one directly connected to the lens under the glass?
    No sir, the ISC is on the back frame of the scanner (at least on the Alphard2 series).
    I don't have a service manual For the Iris2, but I suspect that the CCD is wired directly to the Engine PWB. All the image processing must happen there. =^..^=
      • 23009
      #17
      I suspect that you may not have purchased the CCD calibration sheets, or run the calibration. There is a data table that must be populated to define the CCD colors. =^..^=
      • fishleg
        • Mar 2009
        • 426
        #18
        That's what it would print and then a photocopy of it off the glass.
        I don't think it has a connection board on the 8353ci. We changed the engine board and it returned to normal.
        • sparkycivic
          • Apr 2017
          • 348
          #19
          The ribbon cable that goes from the image scanner carriage to the engine may have deformed contact pads that were making a poor contact or short. I have seen several instances of various ribbons over the years that get wonky with removal/reinstallation and have learned to inspect or re-trim on each handling of the connection. Most notably was a screen ribbon on an M3540idn new out of the box that had a purple screen background.
