kyocera taskalfa km5050 error code cfb31
  • Bobsieger
    • Jul 2025
    [Error Code] kyocera taskalfa km5050 error code cfb31
    my kyocera km5050 copier is showing program loading on the panel when i turn on the machine and after a while is showing error code cfb31.
    what must i do...i have a firmware version 2.45a and tried to update but to no avail.
    please do anyone can help me on this.
  • GESPAGE
    • May 2011
    • 40
    Re: kyocera taskalfa km5050 error code cfb31
    Voir http://www.copytechnet.com/forums/se...earchid=113487
      • 23008
      Here's a little light reading:
      "CFB31" error after 2nd attempt to flash & ~5 min of "Program Loading". "Main CPU: ERROR" after flashing from V2.04C to V2.04D. Blue Screen of Death. Corrupted Main Eeprom. (also possible Op Panel Eeprom). Replace the Main Eeprom (part#: 302GR94201). Reflash if necessary.
      "CFB31" error message after disassembling the panel to clean out foreign matter, then attempted to reload firmware. Tech connected (5) pin harness connector to YC9 instead of identical sized connector YC1. Connect (5) pin operation panel harness connector to YC1. Leave YC9 empty.
      "Program Loading" after successful firmware upgrade. No operation panel function. Firmware reload is not possible. Dirty contacts on the operation panel EEPROM. Clean the contacts for the operation panel EEPROM. Turn OFF/ON.
      How about a song? =^..^=
