Kyocera website missing knowledge base
  • tech07
    • Aug 2008
    • 410
    [Misc] Kyocera website missing knowledge base
    Does anyone that uses kda connect know what happened to the Knowledge base in technical resources? It's suddenly disappeared
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Kyocera website missing knowledge base
    Are you refering to the Kyocera TI_library on CD etc... ?
      • 23010
      I guess I haven't used it that much. Didn't notice. I come here for that sort of thing, or DNet. =^..^=
      • tech07
        • Aug 2008
        • 410
        On kda connect, there is a technical resources link. It has many parts. Download manuals, firmware, utilities, you name it. Until a couple days ago, one of the links was named knowledge base. It included 2 choices..One was helpdesk, which posted solutions to problems called in there. Choice 2 was Q & A. It was filled with great technical bullitens and notes. I really used that.Just wondering..Maybe I'll call them.
        • Tonerkiller
          • Oct 2012
          • 668
          Yea they took away the knowledge base. They want you to use the service portal now. It is not as easy to use as the knowledge base, but it works.
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            i cant use the helpdesk replacement at all.
            all it does is "loading"
            Idling colour developers are not healthy developers.
            • JR2ALTA
              • Feb 2010
              • 2033
              For me when I opened Knowledge Base it would re-open the KDA login page inside my browser window. So i stopped trying
              • kkendric
                • 301
                Log in to KDA, click on Technical Resources, click on Portal, click on search, Important, uncheck all but QA, enter model # example FS-1128MFP, Service bulletins should appear. unchecking all but QA speeds this up. Good Luck, works for me.
                • wragsdale
                  • Jul 2014
                  • 188
                  It seems you must use IE. I'm not sure what version is required but with IE11 I have to add kdaconnect.com to the Compatibility View settings.
                  • jmaister
                    certified scrub
                    • Aug 2010
                    • 755
                    YES IT WORKED!!
                    thx you awesome dude.
