cs-2550 won't add toner
  • mthomp
    • Aug 2025
    already done
    dv unit changed
    dv calibration (ends with dv n/g message)
    forced toner command does not work
    can only bring to ready by manual toner add from gear on toner cartridge
    suspect engine control board but any suggestions before i order board
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    A few things:
    Have you checked if your getting 24v into the toner motor (most motors are 24v dc)? check the toner hopper shutter is being opened fully - i have had a few toners not opening fully so they dont release the toner, the toner gear is not tight on the cartridge- a lot of customers stand the toner on its end making it compact down and so it can't move when the gear turns. The toner motor gear gets stuck so doesn't engage with the catridge when pushed in.
    Incontinentia Buttocks
      • 30420
      toner
      may sounfd dumb
      bit make sure you have the right toner 2550 is its own kind
      1650/2050 not the same
