SMTP and Tier info vanishing?!?!?
  • colin
    IT
    • Sep 2010
    • 38
    Has anyone ever seen a machine completely loose its memory with no errors? We have had a customer call on 2 separate occasions claiming they cant scan to email, and sure enough the settings are just gone. Same thing with the tiers we have setup.
    • 23008
    Re: SMTP and Tier info vanishing?!?!?
    On an Alphard I, I've recently replaced a PBA Main Controller for the MFP dumping the IP address twice a day. Just the IP address reverts to 0.0.0.0
    Everything else holds fine. Does that help any? =^..^=
    • colin
      IT
      • Sep 2010
      • 38
      This is on a new 4551. That information is held on the chip set on the main board correct?
      • Zackuth
        • Aug 2009
        • 448
        I had a customer loose half of the documents they had in their document box. This was on a TA420i. Everything else was fine.
        If at first you don't succeed, redefine success
        • darry1322
          • Oct 2010
          • 817
          Check the error log for F27A codes.
          If the F27A is occurring around the time of the info vanishing, make sure you are at the latest firmware version
          there is info in the firmware release notes about the F27A codes and partial initialization of settings.
            • 23008
            The network settings are held on the HDD. A reformat dumps them. =^..^=
