DF-790
  • senady
    • Aug 2025
    [Jamming] DF-790
    I have a new DF-790. The problem is the machine will come to ready and the finisher is not going through any type of warm up. When I press the start button, the machine shows JAM 0300 on the screen, but machine never tries to pick up paper so there is no paper in machine. If I open the front door of finisher it will clear jam code and try to run again with same results. In service mode I am not able to activate any motors or solenoids for the finisher.
    Does anyone have something like this?
  • Zackuth
    • Aug 2009
    • 448
    Re: DF-790
    Have you looked at the connectors for the finisher that get installed with the bridge unit?
    If at first you don't succeed, redefine success
      • 23010
      Re: DF-790
      Clearly, you've got a communication issue, and the four usual suspects:
      Pigtail
      Main PWB
      Finisher PWB
      Firmware
      ... in that order. You didn't mention the host machine ... are you sure it's compatible? DF-790 versus DF-790(B)?
      • rstarr
        • Aug 2011
        • 9
        Re: DF-790
        Did you install a puch unit if you did plug the shifter motor in
        • NeoMatrix
          Senior Tech.
          • 3513
          Re: DF-790
          Sounds like a firmware issue.
          The TA300ci would jamb random from brand new when all accessory's where installed as new.
          Udate the firmware immediately an you had a working machine.
