FS 2126nfp
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    FS 2126nfp
    Hi guys,
    Does anyone have this kind of issue? Can't calibrate magenta but the right side of print is ok.I try with new belt and drums and clearing memory.
    I am inclined to laser unit?!
    Thanks,Z
  • Tonerkiller
    • Oct 2012
    • 668
    Re: FS 2126nfp
    Did you clean all of the charge roller.
    • Zackuth
      • Aug 2009
      • 448
      Re: FS 2126nfp
      What do you mean by "can't calibrate magenta"? Sometimes the calibration is so off that I have to enter the same last character many times, 5 to 8, to get any kind of result. But changing the transfer belt should have fixed that. Have you looked at the IDC sensor plate? If that doesn't move to uncover the sensor you could be having problems.
      If at first you don't succeed, redefine success
      • AlbertK
        • Jul 2014
        • 90
        Re: FS 2126nfp
        Hi, I would check the Magenta drum unit gears and perhaps the Magenta drum drive gears... Something is loose.... Did someone open the drive gearbox and not put the gears back in their correct place?
        Good luck. It would be interesting to know what the solution was.
        The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
        • zoraldinho
          • Mar 2008
          • 5014
          Re: FS 2126nfp
          Thanks for response dude.Yes.I put new belt and new drums and new magenta developer in a clean machine.
          • zoraldinho
            • Mar 2008
            • 5014
            Re: FS 2126nfp
            Hi Zack.
            Thanks for response.Im a Canon tech so far and i need some sugestions here.
            I mean magenta is out of range on the left side of the print.(check attachment).
            Sensor plate is moving ok and sensors are clean.
            I can't correct magenta with registration correction chart because lines are far away.
            • zoraldinho
              • Mar 2008
              • 5014
              Re: FS 2126nfp
              Hi Albert
              Gears! Interesting.Gonna check!
              Regards,Z
              • Zackuth
                • Aug 2009
                • 448
                Re: FS 2126nfp
                Originally posted by zoraldinho
                Hi Zack.
                Ok, in this case you will have to keep entering the same letter or number several times until the chart lines move. Use the last character (either I or 9) that the colored lines have shifted past.
                • tmaged
                  Owner/Service Manager
                  • Oct 2008
                  • 1885
                  Re: FS 2126nfp
                  There is a bulletin that addresses the registration problem. Check the reg shutter is working. Replace the transfer belt. Use special firmware to reset the registration.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • zoraldinho
                    • Mar 2008
                    • 5014
                    Re: FS 2126nfp
                    [/B]
                    Hi Zack,
                    Eight times entering letters and numbers bring results!Print was awesome for 15 minutes.I believe auto callibration make colour reg. bad again.
                    • zoraldinho
                      • Mar 2008
                      • 5014
                      Re: FS 2126nfp
                      Hi dude,
                      I can't find this tool on the partner site.Do you know maybe the name or the title exactly for this tool?
                      Thanks,Z
                      • Tonerkiller
                        • Oct 2012
                        • 668
                        Re: FS 2126nfp
                        Just keep adjusting. Made sure that you are adjusting in the right direction. You might have to do the max adj 10 times to get it right. Each max adj moves it very little. I have been there.
                        • Kidaver
                          Ghoulscout
                          • Apr 2011
                          • 912
                          Re: FS 2126nfp
                          If you can get it lined up on color registration and then it is going out of alignment after a few auto calibrations then the problem is most likely with the shutter not opening and reading the color patch or a problem with your idc sensor. If the IDC sensor can not read the patch it just keeps adjust out of alignment getting worse each time.
                          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                          • zoraldinho
                            • Mar 2008
                            • 5014
                            Re: FS 2126nfp
                            you nailed it Kidaver! I think the same but i come back with proof.
                            Thanks Tonerkiller
                            Z
                            • tmaged
                              • Oct 2008
                              • 1885
                              Re: FS 2126nfp
                              Here's the bulletin. Following it has worked for us.
                              Hope that helps !
                              -Tony
                              www.dtios.com
