KM 6030 display issue
  • Scottb
    • Apr 2013
    • 308
    See the pic for the issue I have replaced the operation tablet, and sponges, and also swapped the display. I have also cut wire ties. So other than a board issue is there anything else that will cause the lines in the display.
    Scott
  • kkendric
    • 301
    Re: KM 6030 display issue
    Connectors, wiring. Reseat all connectors at front, operation panel connectors at main board and junction on left side.
    • Scottb
      • Apr 2013
      • 308
      Yep thats what I thought at first, it turned out to be the wiring harness from the junction to the board
      thanks
        • 23010
        The tablet won't have anything to do with lines in the display. The tablet is the touch panel access only. The actual LCD display is underneath the transparent tablet, as you know from disassembling it. Re-seating ribbon cables can help in some cases, but most of the time you'll have to replace the LCD display. =^..^=
