Kyocera KM 2530 How do you reset copier to factory specs ?
  • Doug James
    • Jan 2012
    • 935
    [Misc] Kyocera KM 2530 How do you reset copier to factory specs ?
    I have the manuals and am unclear what u code does this... The registration is off and I believe it is a broken mirror. While troubleshooting
    I have it all screwed up... lol
    • 23010
    Re: Kyocera KM 2530 How do you reset copier to factory specs ?
    U021 ... but be absolutely sure you want to do this. =^..^=
    • blsquires
      • Nov 2008
      • 342
      if you have the service manual go to the codes and you will have to do one setting at a time .go to maintenance mode it will give you the the basic settings and the number for the start settings .bit hard to explain but it will say what the start value is and how much you can adjust it for instance it may have zero for the start and the adjustment will say +30 to minus 30.if you know someone with a 2530 you can get the readings from another machine and start there.
      also if you havnt changed any settings print out the maintenance report and it will give you the settings.
      hope this helps
      • Doug James
        • Jan 2012
        • 935
        Thanks so much...
