Kyocera mita KM2550, Displays error code C6400
Re: Kyocera mita KM2550, Displays error code C6400
You are in luck. The 1635, 1650, 2050, and 2550 all use the DV410 developing unit, and probably the same toner.
If you didn't have one of those you might try a DV420 developing unit from a Stratos (2540, 2560, 2040, 3060), but I'm thinking that the programming on the EEPROM would prevent it from being properly recognized.
=^..^=Comment
High Tower
When you read your manual did it say anything about a zero-cross error? That means that it's a power issue, not any part of the copier.
So don't replace any copier parts.
Oh! You wanted a constructive suggestion. Um ... bring your power quality analyzer to document the problem. Shake your head sympathetically. Print off the results. Advise your customer to employ an electrician to install a dedicated circuit.
No need to touch the copier (other than a U163 fuser reset). =^..^=
Thank youComment
I think that this has been covered in excruciating detail. You should draw your own conclusions. =^..^=If you'd like a serious answer to your request:
