KM 8030
  • tcypy1961
    • 773
    KM 8030
    pf drawer 2 is failing to pull the paper through; can the feed pulleys be bought individually??? only through Kyocera???
    Thanks!!!
  • habik
    • 2013
    KM 8030
    Have you actually checked the feed unit? It may be bent actuator causing it to not feed as the paper is hard pressed against it whilst the lift is happening.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
      • 23008
      Re: KM 8030
      I know this is an old machine, but there are a few things you should check:
      1) Does it have the copper colored separation spring at the front position only, and is it set to 2 points higher separation setting than the number written on the frame in blue marker?
      2) Is the Paper Empty Flag bent of broken, and moving freely? If you have a customer that overloads the trays, I've seen 7 flags broken on two machines side-by-side, within a 1 day period. Use the part number from the KM-620/820 (KM-8030 does not list a separate part number).
      3) Are the mylars in good shape? They'll get paper cuts that are not readily apparent that can snag the leading edge.
      Yes, there are separate tire numbers.
      2FB06040 Pickup
      2FB06060 Feed
      2FB06080 Separation
