DP-410
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    DP-410
    ERROR CODE C0410
    DP* communication problem
    Communication fails five times successively.
    sugestion
    Replace the engine PCB or DP driver PCB
    and check for correct operation.
    Customer is experiencing this quite often. Kyocera released a bulletin (sb-7442) about the grounding plate which has worked in the past on other doc feeders but this doc feeder has the updated grounding plate so its not an earthing issue.
    Any body have any ideas before i replace the board or check the harness (doubt it will be that...)
    The machine in question is a km-2550 (i think)
    Incontinentia Buttocks
  • 10871087
    • Jan 2005
    • 1143
    Just ground the mounting brackets of the two motors together with a piece of wire and that should help with the bulk of the errors.
      • 22997
      There is a new style DP main board to solve this problem. I believe the grounding wire was intended as a temporary measure. =^..^=
      • daveh
        • May 2005
        • 13
        KM's bulletin announcing the new board also has the grounding procedure
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          dp-410
          thanks for all the replies:
          i'm ordering the board and sending back under warranty
          • Mark B
            • Jul 2006
            • 153
            I also had two different machines that the cable from the adf to the machine was bad. Wiggle the cable and see if the code comes up.
