Black copy from feeder and glace TASKalfa 520i
  • kaborwen
    • Feb 2010
    • 146
    [Misc] Black copy from feeder and glace TASKalfa 520i
    Hi all,
    I have a problem with a TASKalfa 520i. When copying from glace or DP, it's coming black but all prints are OK. I need solution or service bulletin please.
    The firmware is update.
    Thx.
    • 23009
    Re: Black copy from feeder and glace TASKalfa 520i
    What happens when you scan?
    Does the lamp light?
    Some possibilities:
    Exposure lamp
    CCD
    Scan Control Unit
    Harnesses
    Main PWB
    • kaborwen
      • Feb 2010
      • 146
      Some possibilities:
      Exposure lamp
      CCD
      Scan Control Unit
      Harnesses
      Main PWB
      When color scan it's magenta And B/W it's black. Harkness is good. Exposure lamp ils OK; it's lighting.
        • 23009
        I think you can safely rule out the lamp.
        It probably won't help, but it won't cost you anything but time to re-seat connectors to the CCD and the Scan Control Unit. =^..^=
        • Hose1cook
          Defective Technician
          • Jun 2008
          • 80
          Sounds like you lost your scanner settings, I've had this a few times on 300i's and 520's. You need the special test charts to perform Sim 411 & 425 to get them back.
          • kaborwen
            • Feb 2010
            • 146
            You can see the scans samples. in color and B/W mode. Maybe can help for solution. Thx
            B&W Scan.pdf
            Color Scan.pdf
            • lola88
              • Feb 2012
              • 6
              Yes I would suggest charts. Had similar happen on a M2535 would come out white no image. Performed service modes with special charts all was well.
              • kaborwen
                • Feb 2010
                • 146
                Hi all,
                I replace this part 302KS94080 PARTS PWB ISC SP, and it's all right.
                Bests regards.
