Kyocera KM-4035
  • tcypy1961
    • 773
    Kyocera KM-4035
    When making a duplexed copy on this copier, the second side is lighter than the first. When I checked the U101 settings they are where they should be. Is the transfer roller the cause of this? If not, what could be causing it? Thank you for any help given.
  • robscopyr
    • Mar 2009
    • 54
    Re: Kyocera KM-4035
    That's where I would start. The transfer roller is a fairly inexpensive part and part of the PM kit.
      • 23009
      Re: Kyocera KM-4035
      Also check for a shorting primary. =^..^=
      • tcypy1961
        • 773
        Re: Kyocera KM-4035
        shorting primary???
        • copy
          • 11
          Re: Kyocera KM-4035
          I would try Firmware
          • GUNit
            • Jan 2008
            • 23
            Re: Kyocera KM-4035
            this rings a be it ll im sure you have to change sim 956 from old to new or vice versa something to do with conveyancing section I believe, good luck
