kyocera taskalfa3051ci
  • Northwestservice
    • Jan 2011
    • 140
    just finished setting one these machines up new out of the box it is an IT machine so no manuasl yet. can i just turn it on or is there a proceedure for turning on thank you for your help terry
    • 23008
    Re: kyocera taskalfa3051ci
    No, you can't just turn it on. There's a setup procedure. I suppose it will eventually load enough toner ... but the scanner errors can be irritating. I suggest you follow the setup procedure. =^..^=
