ECOSYS M2535dn jamming
  • copiertec
    • Jan 2016
    • 2211
    #16
    Re: ECOSYS M2535dn jamming
    Originally posted by joelea
    also any part numbers for the drive pack?
    I believe this is the # for the main drive (DR-150)-302H493040
    • joelea
      • Feb 2012
      • 64
      #17
      thanks
      • joelea
        • Feb 2012
        • 64
        #18
        Originally posted by JR2ALTA
        If you're having collision jams caused by a flipped or bent mylar you need to take strong but flexible cardboard (the back piece of a legal pad) and manually force is through the bypass into the paper path. This also works well if scrap paper gets lodged in hidden areas.
        I don't have the drive pack part number as Kyocera's website is currently down.
        • joelea
          • Feb 2012
          • 64
          #19
          Originally posted by Nic Brits
          I have a similar issue with this model range. I have two new machines that comes up with the 4201 jam code to a lesser extent, but have a major issue with J0501, 0511. I have replaced the feed rollers even tough they showed little wear, I also stretched the spring on the sep roller to see if it would help but it didn't. They do AMCV of 5k a month, which I thing is too much. I haven't thought of replacing the clutch as the machines are very new. Any thoughts on this.
          what fixed your issue?
          • JR2ALTA
            • Feb 2010
            • 2033
            #20
            thanks
            Order the clutch wires 302HS46210 too. Odds are 50/50 you will pull bare wires out of the connector because it's so tight.
            • stickfly
              • Jun 2010
              • 30
              #21
              Good evening.
              I know this is now an old thread but can anyone tell me how to get to the mylar tabs in front of the registration rollers.
              I have to change them on a machine this week.
              Regards ..... G.
              • KYO_OEM
                • Aug 2011
                • 721
                #22
                There exists a very old bulletin with needed spare number.
                Also available in current partlist....
                • KYO_OEM
                  • Aug 2011
                  • 721
                  #23
                  • stickfly
                    • Jun 2010
                    • 30
                    #24
                    Thanks for your answers but I already have the mylars, they were delivered last week. I just cannot remember how to get to them in the machine, what do I need to remove. It's been a couple of years since I last replaced them.
                    Rgards ..... G
                    • oreyes
                      • Dec 2023
                      • 1
                      #25
                      Originally posted by Santander
                      Regardless of how many pages the unit has on it, look at replacing the drive pack. We had a new unit a couple of months ago, with only a few thousand pages on it jamming with the same error codes. Replacing the drive pack resolved the issue. Replacing the entire drive pack is much more economical and efficient than replacing just the clutch. Producing 5K pages a month for this unit is a cake walk, we have multiple units that go 10-15K per month without a problem. We even have one unit now approaching one million pages without a problem. Just remember when replacing the drive pack to be very careful when removing the connectors. They can very easily be broken, just pulling on the wires will surely result in a bad wiring harness. Use a sharp pointed tool such as a spring hook to assist in getting the connectors out. If these are new units you can get the drive pack replaced under warranty. Hope this helps.
                      please guide me which is de the driver pack?
