Hdd pb on a km 8030
  • TA ITT FRANCE
    • Jun 2008
    • 6
    Hdd pb on a km 8030
    Hello,
    I have worries of hard disk on a machine KM 8030
    In fact when I make lots of copies
    the machine displays optimizes the execution does not extinguish it could delay the execution.
    Excuse me for my bad English level
    PS : I have already tried to format hdd (SIM 24), but it works
    1 during that month, then the message was redisplayed
    thank you in advance
    Vincent
    • 23010
    Have you tried re-loading the print card firmware and machine firmware?
    I realize it is a translation, but what is the exact message displayed? =^..^=
    • TA ITT FRANCE
      • Jun 2008
      • 6
      Thank you for your answer
      but I have already upgrade the firmware
      the message is translated ... from french to English.
      but I think that in English it should be the same message
        • 23010
        The print card and scan card firmware update separately from the rest of the machine. If you used version 352 this does not include print card firmware. What was the message? =^..^=
        • ebm
          • Apr 2007
          • 183
          Had KM-6030 evrytime give C-0640 HDD code. Tried U024 + U989, no luck. Replace w/new HDD, no more problem. Used generic HD drive from Tiger Direct.
          • vinnyb
            I had the same problem.
            What i finally had to do is replace the hdd with new one.
            Just make sure it is the mita hdd.
            This machine hates generic hdd's.
            Since I replaced the hdd I haven't heard from them.
