Taskalfa 300i f378 error code?
  • Zach G.
    • Aug 2025
    Need help. Code came up, tells me to turn it off the power switch. I looked in the service manual and couldn't find anything. Any ideas?
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Taskalfa 300i f378 error code?
    An error is detected at the
    FAX management section
    1) Format the HDD and check function. (U024 FULL formatting)
    2) Execute the U021 Memory initializing to initialize the controller backup memory
    and check function.
    3) Execute the U671 Clear FAX back up data (FAX DIMM clear) and check
    function.
    (Take cae of the received data since it is cleared)
    4) Replace the FAX_DIMM and check function.
    5) Replace the main board and check function.
    6) Replace the HDD and check function.
    7) Retrieve the USBLOG and contact the Service Administrative Division.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
