km4050
  • Users Tech
    • Nov 2013
    • 85
    km4050
    hello all,
    need help km4050 won't print. i entered status, device/communication and printer says "PAUSING". i turned it off and on but the problem is the same. i did u906, sometimes it says ready and sometimes it still says "pausing". when the printer displays pausing then the machine can't print.
  • Max
    • Oct 2011
    • 562
    Re: km4050
    What have you tried so far ?
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5017
      Re: km4050
      • Users Tech
        • Nov 2013
        • 85
        Re: km4050
        sorry guys i'm a ricoh tech and i'm new with kyocera. i did search a lot about this problem and read the manual before i posted this but i didn't get the right solution that's why i'm asking for your help. it's my first time to encounter this problem where the machine is "pausing" the printer.
        • zoraldinho
          • Mar 2008
          • 5017
          Re: km4050
          No problem! I was joking with Max.
          I'm also not familiar with this model but however im gona help you as far I can.
          Can you print status report from maintenance mode?
          Did you check obvious? (picture)
          Maybe fixing unit can't reach printing temperature!
          Reseat memory.
          • Users Tech
            • Nov 2013
            • 85
            Re: km4050
            [ATTACH=CONFIG]27834[/ATTACH]
            Reseat memory.
            yes i did check that but it won't print unless the printer in the device/communication displays ready. checked many times and waited a long time but printer still displays "pausing".
            the machine is being used as a photocopier only.
            i'll try replacing the fixing unit.
            many thanks.
            • blsquires
              • Nov 2008
              • 342
              Re: km4050
              you may have a dodgy file locked into the server and everytime you switch on the machine it resends it to the printer.take the network cable out switch the machine off for a couple of minutes ,then turn back on and check the status/job cancel button .the next thing if there are no jobs on the status page .you will have to delete the job from the pc or server.then plug your network cable back in.
              • Users Tech
                • Nov 2013
                • 85
                Re: km4050
                the machine is used as a stand alone photocopier only. not attached to a pc or a network.
                sometimes when we turned it on in the morning the printers displays ready but later the printer will display "pausing". but sometimes also when we turned it on in the morning the printer displays "pausing" already.
                  • 23010
                  Re: km4050
                  I think I'd start with firmware. =^..^=
                  • Hankster
                    • Jun 2011
                    • 18
                    Re: km4050
                    Yep firmware! Hd format!
                    • zoraldinho
                      • Mar 2008
                      • 5017
                      Re: km4050
                      Hankster and cat have right.I check some bulletins and found many corrections on engine firmware.Start with that! It's the cheapest!
                      • Users Tech
                        • Nov 2013
                        • 85
                        Re: km4050
                        i think your right zoraldinho!
                        i replaced it with another fixing unit and so far there's no "pausing" problem the whole day!
                        many many thanks and more power!
