Quiz Question
  • rich2764
    • Apr 2025
    Quiz Question
    Hyperthetically assuming no error codes happen, if an exposure lamp goes dim or blows on a digital copier would you get light or dark copies?
    One assumes you would get light copies? If the optics go dirty on a digital then you normally get lighter copies, but my troubleshooting manual for a kyocera 2050 says i would have black copies if the lamp failed, which I am questioning.
    Does anyone know the correct answer?
  • nmfaxman
    • 1703
    Tested this theory at a Toshiba class.
    The answer is blank copies.
    We turned off the error codes and unplugged the lamp.
    • rich2764
      • Apr 2025
      yes that is what I always thought too. many thanks
      • 10871087
        • Jan 2005
        • 1143
        Originally posted by rich2764
        Hyperthetically assuming no error codes happen...
        Blank pages because the CCD or CIS would calibrate to the white patch which will not be illuminated.
        But you would get a code
        What do you get if you lay a mirror on the Glass? Why?
          • 22921
          It depends entirely on the particular model of copier. Copiers with potential control systems if the lamp goes out after warmup will make (1) black copy, then the rest will be blank. This includes most of the segment 4 & faster copiers.
          Segment 3 & slower typically do not use potential control, and will produce at least (1) black copy, possibly more, then error out.
          An interesting bit of trivia is the lamp does get dimmer with age, but on the last few copies before it blows the lamp will be very bright, giving light copies on the last couple before it blows. =^..^=
          • selig67
            • May 2008
            • 156
            Hyperthetically??
            lol
