552ci c3018
  • oh_no_its_him
    • Feb 2015
    • 5
    [Error Code] 552ci c3018
    Its the bigger finisher the code is motor lift tray I've replaced the motor and code came back so I replaced the pwb for the finisher and the code is still coming back what else can I do
    • 23009
    Re: 552ci c3018
    Have you attempted to run the motor in service mode?
    Have you tried removing the motor from it's drive load then power up to see if it attempts to rotate?
    Possible outcomes:
    1) tries hard but can't turn: look for locked up drive component.
    2) sputters half heartedly: possible pinched wire.
    3) doesn't try at all: bad finisher controller, harness problem, voltage missing.
    4) overdrives past it's upper or lower limit: bad limit switch or flag.
    • NeoMatrix
      Senior Tech.
      • 3513
      Re: 552ci c3018
      Is this a newer/different finisher placed onto the machine?
      Try updating the firmware. The firmware should see the newer/ different finisher model.
      • oh_no_its_him
        • Feb 2015
        • 5
        • Warstg_20
          • Sep 2009
          • 72
          Re: 552ci c3018
          finisher have different model? maybe it is not compatible to the newly installed,. all motor will run if they supply volts, it depends on it characteristic or functions were it is used or how it run
          hope it will help
