FS-4020, drum install
  • Hansoon
    • Sep 2007
    • 3347
    Is there a setting up procedure when a new drum is being installed in a FS-4020? Customer scratched his drum with 100K and I have to replace it but am with no knowledge about the machine. Maintenance kit reached 100K.
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • 22927
    Re: FS-4020, drum install
    No set up. The machine recognizes the new EEPROM, and runs a calibration without your intervention.
    Keep in mind that that normally it's the primary charge that gets coated with ozone that causes the quality problems. Sometimes you can clean it. Sometimes it doesn't help enough. The primary charge is available separately, and has been modified several times along the way.
    • Hansoon
      • Sep 2007
      • 3347
      Thanks Cat.
      The drum is scratched by a dumbfuck who tried to remove a jammed paper with a pair of scissors.....
      Hans
        • 22927
        Genius at work. I hope it's billable. =^..^=
