hi everybody...kyocera taskalfa180 it is new .when i turn it on it is displaying message"unknown toner installed"and when i print a report giving a blank paper.what is wrong?... thanks
1) Unknown toner installed means that the machine is not recognizing the RFID tag present on an OEM toner cartridge. I've seen a few bad RFID tags on new OEM cartridges, but more likely you are using non-OEM toner. You have two choices: You can install OEM toner, or you can live with the displayed message.
2) Blank Copies on a new machine probably means that you never read the installation procedure. If you had, you would have noticed that you should run simulation U130 to fill the developing unit from the new toner cartridge. It takes a really long time to fill the developing unit without running that simulation. It would be better if you just followed the installation guide.
thank you my dear..you are right but i did all the installation procedures and i ran the simulation mode that you mentioned with no use..still the copy blank..what i want to know if the message appeared related to blank copy?thank you
No relationship. They are entirely separate events. =^..^=
