FS-C8025 Error 3200 after main PWB & ISU Replacement
  • deactivator
    • Jul 2025
    Hello Guys,
    i got following Problem:
    Machine Kyocera FS-C8025 went into Error 3200.
    Because of different Scanning Issues first of all the ISU Unit has been replaced.
    Started Up the Machine, Same Error again.
    After that the main PWB was replaced and Firmware Update has been made.
    Then The Code 0180 (Machine Mismatch) appeared, Maintenance Code U004 fixed that Error.
    Now it boots up, shows Ready for Copyying for about 2 Seconds and then runs into Error 3200 again.
    Can you Guys please give me any advice?
    Greetings, deactivator
  • laitang
    • Nov 2012
    • 627
    Re: FS-C8025 Error 3200 after main PWB & ISU Replacement
    Did u check:
    - CCD PWB.
    - Exposure lamp
    • kkendric
      • 301
      Make sure that you have not accidently bumped the scanner locking knob, if so equipped.
        • 23008
        On many other Kyoceras, false laser codes can be generated by high voltage charge loss, or possibly bad doorswitches. =^..^=
        • Dyvyne
          • Feb 2015
          • 5
          Deactivator,
          Do check the CCD, ISC board and the Exposure lamp.
          • kkendric
            • 301
            3200 on this machine is not a laser error.
              • 23008
              Good catch. I've replaced a few Main PWB's for this problem. There is a procedure for the board replacement. Did you follow it? =^..^=
