KM-5050 CFB2C Any suggestions?
  • selig67
    • May 2008
    • 158
    Tried reformatting the hard drive, now considering replacing boards.
    • 23010
    First start with loading the newest firmware (currently version 2.06). This may solve your problem. Pay very close attention to any failures to update. If one of the DIMMS fails to update reseat it, try the firmware again. If it still fails replace that DIMM and load the latest firmware.
    Note: The new DIMM will not have the most current firmware, and possibly not even usable firmware. Count on loading firmware immediately after a DIMM replacement.
    Many of the CFXXXX codes are firmware related. This is a cheap place to start.
    • selig67
      • May 2008
      • 158
      thank you
      I will give it a try
      • 10871087
        • Jan 2005
        • 1062
        Some of the early machines had DIMMs that were a little flaky and would cause CF codes. Kyocera's hotline might have some info for you. I would re-seat the DIMMs a suggested by Blackcat but if that doesn't help I would look at replacing them before you replace any boards. Do you have the machine on a good power filter?
        • 10871087
          • Jan 2005
          • 1062
          I just realized that was my 500th post.
