hlo very one ...please how can store image or text from scanner to usb flash memory in kayocera km 4050 any one can help me and thanks to all
falah taan
Tags: None
Re: falah taan
I'm pretty sure you can't store files. Flash memory is for printing only.Read user manual.
A picture is worth a thousand words -
Re: falah taan
Originally posted by terramobilThat is no problem, insert USB key in the USB connector (right hand side of operation panel cover). Wait a few moments, a message will appear in display, press "yes". Now you can see the files and folders of your key. Press the "Store File" in the lower right corner of the screen. Thats it.
Not available on the KM4050 . Print only.Comment
Re: falah taan
http://www.manualsprinter.com/manual...ra_KM-4050.pdf
In other words RTFB!
You will never learn any machine if someone always GIVES you the answers.
Call the 1-800 line for the manufacturers.
They get paid to verify the proper steps.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
