CS-4551 ci default fax tray
  • djdavis
    • Aug 2025
    Good morning all, I have done a quick search online and on this forum to no avail,...
    I have a CS-4551ci with fax card. I am running this device on my Windows print server with the fax driver.
    Incoming faxes are defaulting to tray 1 on this machine, tray 1 for this location is set to letter/letterhead. Incoming faxes are causing the machine to lockup until letter/plain paper is set on tray 1. I cannot find anyway to change the default drawer for incoming faxing.
    I have 4 drawers in this machine
    I have tray 4 set to default for all jobs
    Any help would be greatly appreciated!
    Shawn
  • kkendric
    • 301
    Re: CS-4551 ci default fax tray
    KYOCERA Document Solutions | Business Printers, Color MFPs and Document Management Solutions
    Select Downloads.
    Select Category
    Select Model
    Select Technical
    Select Manuals
    Select Fax W operation guide
    If this does not work Hire a Technician!
    • djdavis
      wow, ok... Ya sorry I didn't specify I have looked through all the manuals.
      So, I figured it out with some playing. At least one drawer has to be set to auto paper size and plan paper. Our tray 3 and 4 are 1500 capacity and were set with letter and plain, this was forcing the job to tray 1 even though tray 1 was letter and letterhead. The manual states how to paper but didn't state it MUST be auto size. Thanks for the help..
        • 23010
        Yes, at least one tray must be set to auto size detect, preferably all of them
        When printing facsimile Kyocera machines use a priority list starting with the size that most closely matches, then switching to the one that next most closely matches, etc.
        It's sort of ass-backwards, but the best way to specify a fax tray on most Kyocera MFP's is to select a specific media type (say ... Custom1), then specify that all facsimile must print onto Custom1). When it runs out of fax-specific paper the machine will ask you to load paper rather than switching to a paper that doesn't really match size-wise.
        I don't think you'll find any of this information grouped together in any one manual. =^..^=
