Kyocera TA-250ci stuck in "welcome" screen
  • copier4you
    • Dec 2014
    • 18
    [Dead] Kyocera TA-250ci stuck in "welcome" screen
    Hi everybody,
    I have a TA-250ci, stuck in the "welcome" screen and it seems that the only way to fix this problem is to re install the Firmware
    I have Googled for the files and checked past threads here to no avail!
    The only download site I found that claims to have this file, downloads Trojans!
    If anybody has the right files could you please send them to copier4you@gmail.com ????
    Thank you very much for your help.
    Frank
  • Schluken
    • Sep 2014
    • 13
    Re: Kyocera TA-250ci stuck in "welcome" screen
    Log on to kdaconnect and download the firmware from there
    • Tonerkiller
      • Oct 2012
      • 656
      I never found the firmware to be the fix. It was always a memory, dim, or hd
      • copier4you
        • Dec 2014
        • 18
        I'm not authorized and can't do it!
        Wish I could.
        Can you? If so, can you download and forward to me?
        I would really appreciate it!
        Thanks again
        • copier4you
          • Dec 2014
          • 18
          The F/W is out there and Kyocera Tech Support has been sending it to techs around the country. It's a very common "field" request. I'm just surprised that nobody here has it or is willing to share. I mean, if I can do something for my fellow techs, it will be my pleasure to do so!
          Thanks again,
          Frank
          • Kyo fan
            • Dec 2013
            • 368
            I don't think firmware will help you in this case. As Tonerkiller said, you should start with hdd and memory 1st.
            • rapidocument
              Multibrands Tech
              • Jul 2012
              • 381
              Copier4u
              Check your messgs.
              Regards.
              Jaime
              My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
              • copier4you
                • Dec 2014
                • 18
                I think you are righ about the DIMMS and HD.
                Are the memory and HD proprietary or can I get them on my own?
                Thanks again
                Frank
                • copier4you
                  • Dec 2014
                  • 18
                  This is a copy of a message I received from Walter just in case there are more people out there looking for answers on this topic.. THANK YOU WALTER!!!
                  "Re: taskalfa 500ci firmware stuck on welcome screen usb keyusb keyusb keyalso
                  • copier4you
                    • Dec 2014
                    • 18
                    THE SOLUTION
                    I tried to upgrade the FW but (as Walter mentioned) when I turned the machine on, with the USB Flash plugged in, NOTHING was happening and no motors were turning. At that point I knew I had a different problem.
                    I disconnected the RADF and the Interface board that connects the feeder to the copier's pain PCB. I turned the machine back on and it came back to life!!!!!!!!!!!!!
                    I checked the harness connector to the pain PCB and I found it broken on one end. Naturally, someone must have pushed the cable from the RADF to the interface board in too hard, the interface board was pushed back, cracked on one end and was not sitting right on the main PCB.
                    I realigned the connector, reconnected everything, run 1087-1087 -906 and everything is back to normal!!!
                    Thank everybody for your help. This is a great forum
                    Copier Techs are the BEST!!!!
