KM 1650 with patches of faint!!!
  • same_steven
    • Jun 2011
    • 52
    I have this KM 1650 that gives me copies with faint patches but when you do print outs, the printouts are perfect!
    I have cleaned the optics and infact, I even replaced the scanning lamp and the board below it but I am getting the same results.
    then I replaced the High voltage board but nadda.
    Is it something to do with the CCD? someone help!
    • 23008
    Re: KM 1650 with patches of faint!!!
    Hare you read any of the posts on this topic? In essence, the ozone emitted from the primary charge collects on the mirrors and slit glass.
    Yes, yes ... you cleaned the mirrors. Did you actually look at the mirrors after you cleaned them? I'm betting that there is still an ozone coating that you have not cleaned off yet. Use 99.9% pure alcohol, and a soft towel.
    Are you interested in preventing this in the future? Use self-adhesive mylar stickers to close off all orifaces between the fuser and the scanner. If you want to go a step further, line the left side covers with 4mm foam to limit ozone seeping in around the side covers. =^..^=
    • bigdaddy
      • Feb 2015
      • 35
      Great idea!
      • ranachinna
        • Mar 2015
        • 11
        Great idea friend
        • Zackuth
          • Aug 2009
          • 448
          I always clean glass and mirrors first with water, then with alcohol and finally gently buff the glass and mirrors with a dry soft cloth. It's a lot of steps, but it does get them clean.
          If at first you don't succeed, redefine success
          • eddie110171
            • May 2012
            • 133
            We started using windex it leaves so much less residue than the Alcohol. Leaves the mirrors much cleaner.
            • Corder
              • Nov 2014
              • 105
              Have you cleaned the copy glass itself from inside? Espesially white shading stripe?
              • AlbertK
                • Jul 2014
                • 90
                Hi. Did you check the copy default settings...? maybe someone had itchy fingers.
                I would try swopping the developer unit aswell...if the counter is high. Print and copy dont always use the same grade settings as would be expected.
                Let us know
                The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
                • Corder
                  • Nov 2014
                  • 105
                  Let us know
                  Replacing dev unit won't take you anywhere when test print is ok.
