Kyocera KM3035 System error when printing (Intermittent)
  • skibum
    Independent Service Tech
    • 234
    I have a KM3035 that is giving this message only when printing from tax software. No issues with MS Office documents only the tax software had the error message and additionally text is missing from the printed document.
    Secondly, the printed tax form 1040 is also missing text but ti is only a certain font it appears. They can print to other devices ok (Canon IR advance 4245 works fine with tax software.
    Any help would be much appreciated.
  • blsquires
    • Nov 2008
    • 342
    Re: Kyocera KM3035 System error when printing (Intermittent)
    go into your printer driver click on printer preferences.go to image.go to fonts
    change from download as outlines change to download as bitmaps.also make sure that adobe is up to date
      • 23010
      Which system error? =^..^=
      • nmfaxman
        • 1702
        I would contact the tax software company to see if they support the equipment.
        • skibum
          • 234
          "System Error" turn off main switch is how it was relayed (no code present is how the customer relayed it to me). The last error code was 1/09/'15 3:10 C4200. I forgot to mention that I never actually saw the message. I saw the printed docs with missing text and how they should look.
          I had the customer contact the tax software folks to see if there were any changes/problems that could have messed with their fonts. It is odd that it works randomly and it is happening from more than one computer when using this software.
          The driver change is the next step, download fonts as bit maps.
          • Kyo fan
            • Dec 2013
            • 368
            Clean the laser unit.
              • 23010
              False laser codes can result from primary charge arcing, or a failing door switch. Actual laser codes are usually caused by the laser. =^..^=
              • kkendric
                • 301
                Insure that the Print system firmware and NIC firmware are up to date as well.
