C-2300 with TASKalfa 820
  • kaborwen
    • Feb 2010
    • 146
    [Error Code] C-2300 with TASKalfa 820
    Hi all, I have got C-2300 with TASKalfa 820 six months later and I have replaced the fused motor. Now it's come against but the motor is not damage cause when i turn off and on the machine, it's can work around 2000 copies.
    I want to know if there is a SB about this code.
    Thx.
    • 22999
    Re: C-2300 with TASKalfa 820
    If you're getting toner buildup on the upper fuser roller, the friction of that hot toner against a heavily toner packed web will slow down the fuser drive motor.
    If you see heavy toner buildup on the upper roller and web, replace the upper fuser roller, and manually advance the web to a clean spot. Then adjust web advance in simulation 194 down from default Count: 66 to as low as 33 (number of clicks between web advance pulses, decrease by increments of 5), turns to 3. =^..^=
    • kaborwen
      • Feb 2010
      • 146
      Thanks blackcat4866 for replay.
      Please can i get the part number of the upper fuser roller?
      Thanks.
        • 22999
        2FB20060
        Kyocera KM8030 Upper Fuser Roller, Genuine (R7130)
        • kaborwen
          • Feb 2010
          • 146
          Thanks you very much. I will check and let y ou know.
