Loop sensor non arrival jam J410x
+ More Options
Posts
  • Nic Brits
    • Aug 2025
    [Jamming] Loop sensor non arrival jam J410x
    I Have a TaskAlfa 3050ci that comes up with a J410x with every attempted copy/print from all cassettes. I have replaced the modification to the registration section. Any ideas?
  • wragsdale
    • Jul 2014
    • 188
    Re: Loop sensor non arrival jam J410x
    Have you cleaned the loop sensor? I have seen heavy dusting machines that cover this sensor and a cause continuous jams. If your jam is at or past the loop sensor, this is likely your problem. The sensor in question sits above the transfer section on the conveyance unit.
      • 23010
      I have a vague recollection of a loose harness connector at the machine side of the right door. The wire harness is a bit short. The previous techs had replaced the whole door assembly, the engine board, and the wire harness assy. But on final assembly the same connector pulled loose.
      I removed a section of the harness from the looms to gain about an inch in length. It was awkward and inconvenient to make the final connection at the modular connection, but it can be done with patience and dental implements.
      Here it is:
      http://www.copytechnet.com/forums/ky...tml#post448852
      • subaro
        • Oct 2010
        • 1274
        Below is from the service bulletin
        Measure for J410x (Loop
        sensor non arrival jam)
        x: Paper feed cassette
        When the roller is new and the conveying force is stronger, registration roller
        and middle roller may pull the paper against each other during the secondary
        paper feed operation. As a result, middle motor and registration motor may
        come out of sync, triggering the J410x jam code. As a measure, the
        following change is implemented.
        [Change]
        Change the current value of middle motor to prevent the motor from coming
        out of sync.
        Did you update the firmware ?--- the above measure and more is for firmware level,, see below
        Firmware upgrade (Upgrade Pack Ver. V8.00 november 26-2014
        • Nic Brits
          Thanks for all the replies. I managed to find a complete conveying section which I then replaced yesterday. So far so good.
