KM5050 Touch Panel Calibration Issue
  • Neos Eye
    • Dec 2010
    • 20
    Every time I open (turn on) the copier I have to calibrate again the touch panel on U201..
    It seems that its not saving my recent calibration..Did I miss anything?
  • copyaction
    • Oct 2007
    • 991
    Re: KM5050 Touch Panel Calibration Issue
    You need to replace it. 302GR45051
      • 23007
      You'll probably need to change the tablet. It's the glass + plastic top surface over the LCD display. It's very common during the moist times of the year to have the conductive adhesive loosen, that attaches the ribbon cable.
      http://www.copytechnet.com/forums/ra...tml#post311379
      • Neos Eye
        • Dec 2010
        • 20
        Im planning to replace the touch glass..I did check replace the whole panel from a good copier..hoping no more re calibration..But the same thing happen..Turning off the unit losses its calibration setting..It happens now on my 2unit KM5050..
          • 23007
          Do you lose the date/time also? Any other data? Like address book or network credentials?
          • Neos Eye
            • Dec 2010
            • 20
            I ddnt lose any data and time settings..Is there an onboard battery?
              • 23007
              As far as I can tell, there is no replaceable backup battery. Losing the date/time would have been confirmation, so I wouldn't be too worried about that. =^..^=
              • Geo
                • 662
                Be sure to replace the 4 foam spacers between the touch pad and screen, over time the spacers compress and will cause problems.
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  we have two that just died. Its time.
                  Idling colour developers are not healthy developers.
