Default I.P. Address for the NS-30G (NIC)
  • Mr Davo
    • Dec 2011
    • 35
    Hi Everyone,
    I have the KM-1650 with the add on 'scan to email' functionality, made available through the NS-30G module. I just reset the NS-30G which is essentially a network interface card (NIC), however I cannot find the default I.P. address for the card no matter 'how hard I Google it'.
    Furthermore I have used the MAC Address utility from Kyocera, http://d.imgsw.com/sw/swchannel/Cust...kcardsetup.pdf, to no avail.
    Does anybody know the default I.P. address for the NS-30G?
    Kind Regards,
    Davo
  • subaro
    • Oct 2010
    • 1274
    Re: Default I.P. Address for the NS-30G (NIC)
      • 23008
      The default is DHCP, so it could be anything. The way I usually deal with this is to let the scanner pick up a DHCP address. Use a utility like NetScan to browse the IP range, creating a list of network devices. Pick the hostname of the scanner out of the list, and there is your IP.
      http://www.softperfect.com/products/networkscanner/
      • Mr Davo
        • Dec 2011
        • 35
        Hi Guys,
        Thanks again for your helpful responses.
        Subaro: The guide that you provided gave me access to many settings, including the I.P. address...much appreciated!
        Ultimately the printer was left off over the weekend, and after being turned on again (this morning) it is reachable on the original I.P. address.
        I think that the printer / scanner just had it's 'knickers in a know'.
        Kind Regards,
        Davo
