C-6610 with TA-8000i
  • kaborwen
    • Feb 2010
    • 146
    [Error Code] C-6610 with TA-8000i
    Hi all,
    My costomer get C-6610 coming time to time on TA-8000i. I checked conectors, replace fuser unit, but not OK.
    Any idea or SB?
    Tanks.
  • blsquires
    • Nov 2008
    • 342
    Re: C-6610 with TA-8000i
    6610 is a fuser release motor error .first i would check the power supply going into the machine and see if its a constant voltage .
    • kaborwen
      • Feb 2010
      • 146
      The machine is working with UPS.
      • blsquires
        • Nov 2008
        • 342
        as per manual. check motor operation in u030 check fuser release motor ,check the drive gear to see if it can be turned check connector yc26 on engine pwb for loose connection.
        check software and update to latest if necessary.
        last replace engine pwb
          • 22599
          I've seen these codes too, but don't have anything informative to offer. The code clears, and you can test the motor all you want. It won't error again for a few days. New sensors and new fusers haven't helped. =^..^=
