FS-4020DN error C0990
  • lebo
    • Aug 2012
    • 88
    What does mean this error message C0990 on FS-4020DN? Thanks for help
  • Kyo fan
    • Dec 2013
    • 368
    Re: FS-4020DN error C0990
    There isn't error like that for that model. Don't listen to the client, go check the error for yourself.
    • lebo
      • Aug 2012
      • 88
      I am sorry but this error is listed in eventlog twice during last time.
      You are right this error is not noticed by service manual even not by its last 5th revision.
      So I decided to ask for help in this forum, because I am going to replace maintenance kit and I am worry about future problem.
        • 23010
        If I were to take a WAG, I'd say it was related to the power supply. In the Saturn Manual C0980 means 24vdc is absent from the power supply. You might also let your power quality analyzer spend the night taking reading on the wall AC. =^..^=
        • Kyo fan
          • Dec 2013
          • 368
          Scan and post that event log here if you can.
          • lebo
            • Aug 2012
            • 88
            Stat1+elog:
            elog.PDF
            • Kyo fan
              • Dec 2013
              • 368
              First, you don't need to replace Maintenance Kit at 128k pages, these can go up to like 500k without replacement. I've managed to find this code for the old KM-C2030 and it was:
              Code
              C0990
              Description LCC Lift-Up Motor malfunction
              Remedy 1 LCC Lift-Up Motor turns after the LCC Drawer has been slid into position while the LCC Drawer is being used. NO: Change motor. Change LCC Control Board.
              A work colleague of mine told me that this code usually comes with F040. What you need to do is give this machine a good cleaning, vaccuming and latest firmware upgrade (09.00.0010).
              • lebo
                • Aug 2012
                • 88
                Code
                C0990
                Thank you for your time.
                Maintenance kit is needed to be replaced due to damaged surface of OPC drum, teflon heat roller and main charger. All of these parts left on the printed pages some spots. Pickup segment are not in great condition as well. So I recomanded to customer to replace complete MK-360 together with good maintainance (all for 270USD + VAT) New FS-4200DN is twice expensive.
                I think FS-4020DN are better printers to the new FS-4200DN.
                I am sure that new FS-4200DN will need my service sooner to repaired FS-4020DN
                • chinxxx
                  • Jun 2015
                  • 35
                  รวดเร็วก่อนใคร ระดับคุณภาพเรื่องฟุตบอล ได้ที่นี่ ฟุตบอลสด
