km 5050 lockup
  • iceman490
    • May 2014
    • 46
    km 5050 lockup
    Looking for some help on a kyocera that has me stumped, very intermittently it locks up and has to be rebooted. Customer uses it for primarily printing, and large scan jobs (200+). I have upgraded firmware replaced the system memory the memory dimmer chips and the hdd. Any suggestions would be great thank you
    • 23006
    Re: km 5050 lockup
    "Locked up" meaning ... totally unresponsive? Slow panel response? slow printing? dropping off the network?
    Am I getting close yet? =^..^=
    • iceman490
      • May 2014
      • 46
      Re: km 5050 lockup
      Machine operation locked up (stops printing) operation panel will still beep but is completely inoperable
        • 23006
        Re: km 5050 lockup
        These lockups can be a premonition of a HDD failure. =^..^=
        • iceman490
          • May 2014
          • 46
          Re: km 5050 lockup
          I'll keep that in mind next time I'm at the customers location. Any other maintenance codes I can run to confirm a failing hdd?
            • 23006
            Re: km 5050 lockup
            I believe that there is a HDD diagnostic, but it's not conclusive. I've had HDD's that passed the diagnostic, that failed the next day. =^..^=
