TA5551ci C5101-C5104
  • AlbertK
    • Jul 2014
    • 90
    Good day all
    Any one had this before?
    This machine is begging to be bounced...I have followed all the instructions in the manual, firmware updates, replaced all the PWB's as in the manual problem solving list but these code keep popping up, anything from C5101 to C5104. I know it has something to do with the High voltage....but what else if High voltage, Power supply, Engine, drums,drum motors, another set of main charge units...
    I can understand one machine, but four machines with the same symptoms??? what gives?
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1869
    Re: TA5551ci C5101-C5104
    I've seen posts that say to make sure the main charge counter was cleared when doing maintenance. The voltage adjustments are set according to the amount images.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • MDR24
      • Apr 2013
      • 64
      Alot of techs having this issue they reset sim U119 and forget about U930. Reset sim U930 and chances are you'll not see the code again.
      Good luck.
      • AlbertK
        • Jul 2014
        • 90
        Good luck.
        Thanks yes, I have done this....It solved one machine (I hope) but the other ones still gives me these errors.
        Thanks for the input guys !
        • Kyo fan
          • Dec 2013
          • 368
          It usually happens when tech's don't follow the procedure to the end:
          Memorizing this helps curing many headaches
