7550ci Black blotches
  • monstott2010
    • Jul 2025
    Suggestions please...
    Customer has a 7550ci, getting series of black oval/blotches randomly (not every page) at trail end only, 11x17 100lb Text paper, duplexed (mostly only on first page printed, occasionally on second side)
    Have changed black charge roller, secondary transfer roller (improved issue but not resolved), replaced complete vertical path (pull out door) all to no resolution... have not seen this on 11x8 1/2 paper at all7550.pdf
    • 23003
    Re: 7550ci Black blotches
    What do the fuser inlet guides look like? Perhaps the curl of the paper is dragging the unfused image across the fuser inlet guide.
    I agree that it looks a little like a charge problem, but I don't think it is. =^..^=
    • Kyo fan
      • Dec 2013
      • 368
      There's a bulletin on it from February 2015. called 2LC-0108 (D024) "Measure against the Vertical Black Streak". Apply that for 7550ci and you should be ok. Also, make sure you have the latest firmware on it.
      • monstott2010
        Replaced charge rollers, have not seen this occur since then...
          • 23003
          Congratulations, and thanks for posting back. =^..^=
